a35 reed block
If I wanted to put a reed block on my a35 70cc alukit. Whats the best one to go with? Also which one will require the least modification to fit properly.
Re: a35 reed block
Stock
Re: a35 reed block
I have a polini reed block with .3 mm carbon fiber reeds.
This one: https://www.treatland.tv/puch-polini-kit-reeds-p/puch-polini-reed-213.0017.html
$20 shipped
Re: a35 reed block
https://www.treatland.tv/malossi-phbg-reed-intake-block-p/malossi-phbg-reed-intake.htm
I put that on, but be ready to build a custom intake and have to drop your engine every time you need to make an adjustment to the reed block
Re: a35 reed block
How do you guys feel about a reed cage with 4 pedal reeds on a tomos jug? Is it possible? I havent seen one personally, but it would be cool if it could work.
Re: a35 reed block
it DOES work
Re: a35 reed block
hhmmmmmm, is there alot of modifying that needs to be done to fit it? Whcih one might work best?
Re: a35 reed block
keep in mind im running a 22mm carb and I've notice alot of the reed cages are recommended for around 16-19mm.
Re: a35 reed block
^ just swap out the reeds and blast.
