qt50 clutch springs
I would like to know what would happen or what is the point in adding stiffer/ heavier clutch springs on my 1979 yamaha qt50.
Re: qt50 clutch springs
ブロック 666 /
Stock qt springs start engaging around 3500 rpm from a dead stop.Hole shot springs engage a bout 4400 rpm.I have been checking out and thinking of the 30 or 40 lb springs treats got.If you swap pw50 gears on the back you need higher stall springs.
