Re: air leaks in my pipe
Rambo Donovan /
Leaks will cause issues they will give you to much flow or not enough back pressure so the engine will not run effectively, Hence the shape of a pipe. its kinda like a garden hose the thinner the outlet more pressure the less it just flows out. this isn't exactly true but just putting a general idea down. the way the gasses flow effect performance. Eg. Low end mid range or high end pipes. the science exactly is beyond me. 2 cents. Enjoy.
