sims pipe
charles benda /
i just baught a sims pipe for my 76 moby how do i unrestrict it for performance
Re: sim pipe
charles benda /
need to unrestrect a sim pipe for 76 moby eny help
Re: sim pipe
bump
Re: sims pipe
Re: sims pipe
2 % Wrote:
> give this a read it may help
> http://mabecanemobylette.freeforums.org/moby-sim-e
> xhaust-t736.html
That only helps with the old style SIM pipe. With the new one you need a stepper drill bit like this;
If it fits into the silencer then you are good to go. There is a second plate inside that needs to be drilled to match the one on the back. When your stepper bit drills through the second plate then you are done.
Do not drill the one on the back larger. Only make the 2 match. (edited)
