Should I expect more? or just be satisfied. Noob ALERT
.♠.MSG .♠. /
So I just finished repairing all the bullshit airleaks and seals on my 04 Targa.
Runs great, did some minor tuning but Im not sure if I should expect more from it or is it performing to its specs.
Im a total noob when it comes to performance tuning.
Going to Ghost Rally this weekend and just wanted to have it running at its best.
I have:
A35
70cc Airsal
Stock CDI
27T front
22T Rear
21mm intake
21mm carb
Malossi air filter
Weak Ends pipe
I gps'd it and Im at about 50mph.
Seems to be tuned pretty good so far.
Carb is:
37 idle
82 Main
60 Starter
W7 needle.
Doesnt bog nor does it seem to 4stoke at WOT.
SUGGESTIONS?
Should I look into porting?
Should I adjust the rotate the CDI?
Not sure which direction is "advancing" it and I am having an issue with the lights burning out but I ordered a new high current regulator so hopefully that will fix that conflict. (edited)
Re: Should I expect more? or just be satisfied. Noob ALERT
deff full advance (against rotation of flywheel) the cdi, thatll put back the rev limit a bit.
port piston window wider 2mm, remove intake bridge, add piston cooling holes around exhaust.
Overpriced Parts /
50 is good if your running cool
What does your head temp gauge say?
Alejandro Schröeder /
what is a great temp gauge to use?
Overpriced Parts /
Trail tech
It's not great but that's what I base my temps on
Katie Norsworthy /
I have almost the same set up with points instead of a cdi and a techno, my bike is tuned well and im getting about the same speed. I clocked at 54 during Blood Drive but wasnt pushing the kit too extremely hard.
50 is very good with the stock cdi the above fellow is getting 54 since he has points=no rev limiter, more over I bet your getting to 50 in a hurry, advance the cdi gain 2-3 more mph but watch your temps
