What would work best for Tomos a35 pipe and carb.
I have a 1984 Tomos a35 but i don't know what pipe and carb to go with to go with i want it to go as fast as possible I'm running a Tomos A35 70cc 77 Race Kit everything else is stock so what do you guys recommend
These are the pipes i have in mind
Tomos A35 with Puch Kit MLM Cali Pipe
Tomos A35 MLM BK100 Exhaust
Tomos A35 Tecnigas Next Exhaust
Tomos A35 Cali Pipe Side Bleed Tomos A35 Cali Pipe Side Bleed
These are the carbs i have in mind
Mikuni TM 28mm Flatslide Carb
Mikuni TM 24mm Flatslide Carb
Dellorto PHBL 24mm Carburetor
Dellorto 21mm PHBG Carburetor - Racing Edition
Re: What would work best for Tomos a35 pipe and carb.
The first pipe is for a tomos with a Puch kit. Any of the other 3pipes will work.
The first 3 carbs will need need you to do some extensive porting. The 21mm PHBG is a little to big for your kit untouched.
Ok so for any of those carbs to work i would have to do some porting how much? Or how?
ok so far i have narrowed it down to two pipes but still not sure on which of the crabs to use?
Find an a35 port map and go at it. carefully. dremel to start, hand files to finish. look up some tutorials, hours of videos. btw, your fuel efficiency is gonna plummet with any of those big carbs. good luck.
Ok yeah I'll look and what carb would you recommend me ??
Is there anyone running any of these cards and what is your set up
