roller bearing on z50 crank?
hello, just wanted to know if anyones done this.. i have stock bushing in my puch z50 crank now but it looks asthough its on its last legs so as anyone added roller cage bearing in z50 cionrod? i got dmp 70 kit aswell so would adding roller bearing help ?
Re: roller bearing on z50 crank?
Overpriced Parts /
Hmm Mine came with a needle bearing small end stock.
You need to take your crank out of your engine and send it out to shop to get a needle bearing conrod pressed in.
The bushing and needle bearing cage are different sizes sorry.
If you lived by me instead of several thousand miles away I could have pressed in a new bushing and finish ream it for you but You need to find someone who knows what they're doing to do a bushing job on your crank . You can do it yourself but you need a real nos puch bushing because aftermarket ones are loose fit and will spin/fail quick
After you press out the old one and press in the new one you need to finish ream to size with a adjustable finish reamer taking a little bit of brass at a time until the conrod fits perfect. Puch factory tools makes this job easier.
It may take few times to get it right if your first time doin it so buy a few puch bushings in case
Pablo Puchasso /
I bet you mean Za50.
Overpriced Parts /
He is from Europe ^ they got z50s over there not za50s
Thanks ken thats pretty rubbish news :( the bushing i have now has worn so bad i thought it was a quick changeover with the right needle bearing but it obv looks like more work than i thought which is a shame. is there anyway i could remove this old worn bushing now and replace with shiny new one? and yeah max its a z50, 2 speed manual
Overpriced Parts /
Yes replace and finish ream just like I said .
Try to find a nos puch crank/pin bushing like I said too
A scooter shop may be able to do the work for you .
Pablo Puchasso /
oh didn't check his location.
