as far as i know, with tachs like this, there is no happening when you use the little switch for 4-6-8, it just changes the resistance, so bust the thing open, play with some resisters and print a new dial on some glossy photo paper, that's mopeds
Jason Collier Wrote:
> just use this
> http://www.ebay.com/itm/300701766592?ssPageName=ST
> RK:MEWAX:IT&_trksid=p3984.m1423.l2649
I believe, in their description, they have the wiring(lines?) all screwed up.
Guessing at wiring= Smoke!
Looks like ALL their wiring insrtuctions are guesses, and poorly translated too.
It isn't how i would wire it.
because this tach is supposed to be sensing the impulse from a single ignition coil running through a distributor, the waste spark/ non waste spark is a moot point. take the # of cylinders and divide by 2 to get the number of coil impulses per engine rotation (4 stroke) so for example, a v8 has 4 coil impulses per revolution to a 4 cylinder's 2 coil impulses. it goes without saving that a two stroke has a coil impulse for every cylinder per revolution.
SO, if the tach is set to 4 cylinder(4stroke) mode, then it will interpret the 1 impulse/rev. of a single cylinder 2 stroke as 1/2 of a revolution of a 4 cyl. 4 stroke (2 impulses/rev.)
IF the impulse were to be taken from a single plug wire of a multi cylinder 4 stroke with a waste spark electronic ignition (like virtually ALL modern vehicles) then there would be no difference in the number of impulses per revolution between a two stroke or four stroke engine, reguardless of cylinder count. this is how the trail tech tach works.
pretty fuckin simple in the grand scheme o things imho.
