Re: Mike Thomas Gila Spacer
Lawrence Au /
I like to make small spacers in different thicknesses for placement ontop of the reedblock, so that the reeds are still close to the cylinder. When you crack the throttle fast, theres a small pocket of air on top of the reeds already from the spacer, so the response is a tad better.
With different thicknesses varying from 1/4"-5/8" you can change how the bike reacts with certain throttle positions ALOT.
If you want my 2 cents, take it off and flip it around so the spacer is ontop of the reeds.
The boyesen reeds are good. But if you want torquey, take a different pipe instead of the Motomatic Destroyer and cut/weld/modify for low end. Take a Treats pipe and reweld for angle-port Gila. And that sir...will rip.
Hope I helped,
Larry -
