Throttle assembly/ should I dremel it out?
I have a 19mm PHBG carb on my a35 and it won't open my slide all the way. I've been looking at throttles on treatland and most with a lot of pull don't have the best review. Do you think you know of any good ones or do you think I would be better off just dremeling it out, is that's even a possibility?
Re: Throttle assembly/ should I dremel it out?
Get a hobbit throttle. It will open anything, and has a rad killswitch for you to use or not use.
The stock tomos throttle will open a 19mm PHBG..unmodified..
Salsa Salsa /
My blog has a diy how to make a sweet puch one a long pull with a dremel. But I can't go and find you the link at work. . . Cornpedxxx.com
This is the one I use. It works great and opens a TM24 easily.
Salsa Salsa /
Bobby Cazeault /
Thanks.
I've modded a tomos throttle that was on a a3 bike. i'd say my vm20 was shorted at least 3mm if not more.
i just got all up in there and found a stop and then extended it. then find the next thing that stops and extend that. I ended up with a few mm over the 20mm i was looking for
