PA50I Clutch Questions
David Klinikowski /
Just removed the clkutch from my PA50I so that I can update the 3 springs with new ones from Treats.....My clutch has two flimsy looking arms instead of the three is see pictured in most of the photos posted. the two springs inside are much lighter than the springs I bought. WTF?
Re: PA50I Clutch Questions
Those are your starter clutches. You need to get the clutch puller tool and remove the spinning metal plate that those starter clutches engage against. behind that you will find your three shoe clutch. Those springs work wonders though! I put the 1500 rpm springs on mine and it rips.
David Klinikowski /
Great! Thanks.
