Re: Atomizer/Infuser pin questions
Jonny Appleseed /
would you say that it's more of a "fine" adjustment? In other words, if i used an atomizer that was one size smaller would that significantly lean out the mix across the throttle range? or would it just be slightly leaner?
would the stock infuser (#209) be ok to use with a 70cc kit? or do people generally use a larger one?
