not sure how to set my idler correctly...help plz
Erneso Hernandez /
I have a 49cc moped. i dont have the original airfilter installed. i dont know how to set my idler the way it should be. if anybody can help me out id appreciate it and i can go riding again!!
Re: not sure how to set my idler correctly...help plz
kristopher maedke-russell /
what carb?
There's one screw.
Turn it in or out and see what it does.
basically you want to set the idle to where if the bikes on the center stand with the rear off the ground, turn the idle screw until the rear wheel just begins to move.
if it's not idling, you need to start checking out what else may be your problem. if it's idling too high no matter what you've probably got airleaks
hope that helps.
