has anyone made a 20mm square port intake?
i have the k star. the intake that comes with the kit is undesirable on a few levels. (difficult to change jets, 90* angle, causes carb to sit awkwardly)
i have a clamp on 21mm dellorto phbg
i was wondering if anyone has made their own square port intake. i have a 90* bend of electrical conduit that fits the carb perfectly, i just need to cut it to size with a pipe cutter. then i figured i'd heat it and shape it to fit a flange cut to match the k star intake port.
anyone have a tried and proven method?
Re: has anyone made a 20mm square port intake?
by the way, the carb uses a sleeve to fit the pipe im using
I did one for a k-star and 20mm mikuni. Not a sweeping bend though, it's cut and welded 90's.
any pics?
looking for ideas. right now my best guess is to cut the electrical conduit to create a spigot style carb, then use some auto hose to link the carb to the intake manifold.
i would really prefer it to look more clean than that though.
The easiest way to form the pipe is to heat it in a forge, or with Oxy/Act. and drive it over a tapered square wooden block that matches your manifold. You can then cut/weld up the new intake to your existing intake flange.
good thinkin. i'll try working something up. thanks
