Piston has a lot of play on the crank bearing
So I am trying to get my friends moped working right. He has got one of them treats reed kits. The piston has a lot of play on the bearing that connects to the crank. Will this be a major problem? The play is happening where that bushing/bearing goes through the hole on the crank.
Is a new crank in order?
Thanks.
Re: Piston has a lot of play on the crank bearing
Christian Giron /
I had the same problem recently
I was told that side to side play is okay, but a lot of back and forth (up and down? pull and push?) play = bad crank. I think my old one had ~3-4mm play and the one in the spare motor with about 1mm of play was okay according to mattology.
yeah its not side to side its forward backward.
Christian Giron /
here's some threads I found
https://www.mopedarmy.com/forums/read.php?6,1842320,1842394#msg-1842394
https://www.mopedarmy.com/forums/read.php?6,1850764,1850812#msg-1850812
https://www.mopedarmy.com/forums/read.php?6,1853187,1853295#msg-1853295
https://www.mopedarmy.com/forums/read.php?6,3098179,3098686#msg-3098686
and a quote from grey
"Grey L (saabsonettguy) — Jul 01, 2010 03:27PM
The tomos A3 manual says it should have between 0.2-0.5 mm axial play in the connecting rod. I dont think puch lists it in their manual, but I imagine its probably pretty similar? "
Thanks a lot.
Seems like he will have to replace his crank. Luckily I already have an extra one.
The ped won't run at all though, not even idle. So I would guess it has other problems? Or will +1mm of play be the culprit?
