puch korado motor or E50
Thinking of a new one speed motor with all the work for my puch. Should I go with a weld build up case type E50 for my bottom end or a bottom end from a korado? I plan on putting on a gila or big port metra. Don't know much about the korado motor other than a ports are bigger, potential bearing problem, and gears somehow reversed. Any info on the korado motor is much needed.
Thanks,
CP
Re: puch korado motor or E50
Overpriced Parts /
You still have to bore out the case for a 80cc ( well actually 74 cc) kit
And metra 80 is not made no more so just get regular cases for Gila then send them to be bored
I have a few e50s
I have one e50 gila
Nothing beats the Korado+65cc hero kit
Korado has 12v
CDI
lite high performance clutch
Well i have an existing e50 with a rito roller bearing crank. Only a polino on it so was going to bump it up to a gila or metra. i have my 80 metra on a za50 welded case right now. Might strip it for the e50. My main concern is if a regular e50's internals are better than the korado internals for high performance use. I need to keep up with the Japanese mopeds and scooters here.
bump. any more inputs on this subject? please.
Beard Road Bruiser (SoB) /
Korado cases (3 bearing) are just fine for modding as long as you use a good trans fluid and change it often.
good luck trying to find a Korado motor.
you seem to be over worried about 2 bearings vs one bearing.
my korado has not blown up yet .not from the lack of trying
What you running coconut? I actually got couple offers for some but not sure if i should pull the trigger.
ive got 3 korado motors all kitted tons of miles on em never a problem with the one bearing setup. only bearing i had to ever replace was on the crankshaft which is totally normal.
i am running the cheapo hero kit 17mm bing. estoril pipe
no need to bore the case out. bolt on kit and go blast.
its way more fun than my gila kit
> estoril pipe
> blast.
Kit with the Monza head or stock korado head?
Cleats Onionpockets /
Depends on how you like your squish band. I loved the way the korado head behaved with my hero kit, but maybe the monza has a different shape to it?
3 bearing regular e50. big transfer meat. ducati points. stock roller crank.
for a gila i'd bore e50 cases. but if i could get korado cases i'd run the hero. no question. i'd way rather have a hero korado than a gila'd e50. not near as powerhouse but that shit is so rad and rock solid.
good info guys thanks. chime in with more if you got'em.
