DIY crush gasket for hobbit/moby just in case
I don't have any crush gaskets, and can't wait for a shipment right now.
so I got some 1/8 copper tubing I found at the hardware store.
1/16 hole inside
Heat it with a fire or torch til red, then quench immediately
Grind/sand edges in a wedge and opposite wedge pattern ,
then bend around a scrap of handlebar (7/8)
Anneal again (heat/quench)
Plop it in and tighten and off you go!
I put the wedge side towards the head so it cant expand outward.
I needed it because I just finished modifying my hacked up combo pipe after derestricting it...
I hate those simonini silencers!!!! So restrictive...had to chop that up too.
With the restrictive pipe it hit the powerband, but no power anywhere else.
Now it finally has power in a much broader range.
Re: DIY crush gasket for hobbit/moby just in case
the things people do to make their hobbits run cooler.
anyway, I like your bike. good job.
Probably could have solder the ring shut, but it doesn't matter really. Nice work. Your moped looks like a pony keg of beer on wheels.
Whoops, it was labeled as 1/8,
But it's actually 3/16 diameter, with a 5/64 hole.
My hobbit is most likely the coolest running hobbit now with no hpi or water cooling.... Now that the restriction in the pipe is gone, I can barely get it to 375, even with mountainous hills.
Works for me!
Sick!!! Nice work!!! ROAR!!!
neato!
my favorite Is the athena hobbit gasket I got from Ryan N. I got a few of em now.
hey jbot so I need to find the same fan you got. Honda elite rad fan or something. I would love to rock a hood scoop on my hobbit.
EXCELLENT IDEA!!!
The fan I use is off of a Honda elite 250 or helix 250.
They are about $20 on eBay.
I blasted in the extreme heat at Calirally yesterday (102deg I think)
And it seemed that the scoop and fan did their job. I did a survey of the riders with cht's, and all the different highly tuned bikes were running 420-430 wot, and that's right where mine was staying as well.
Then once I slowed down the temps dropped fast, unlike usual with a heat soaked DR.
The only downside was that I didn't adjust rollers for my newly lengthened and modified pipe, so I wasn't fully variating. Getting close but I was a bit too light..
Sad to see Dave and his 612deg seize....:(. Ouch!
612* I thougt the trail tech maxed out @ 500* . Thats where mine stays .
612!!!?!?!! HOLY!!!! CALIRALLY!!!! Wish I was there bro!!!
every hobbit thread ends in some sort of discussions about temps…..
