High RPM Blowback, and Lean.
Ed - Dead Possums /
So I am tuning up this new Carb and getting lots of fuel blowing out when I'm at WOT. More than i'm used to on other builds I've done. More at wot/high rpm than at low rpm. But my plug chops say that I'm running lean. If i upjet won't i just be blowing more fuel out?
70cc TCCD
high torque head
case/intake matched
needle bearing crank
16x40 gearing
boss circuit pipe
Timing at 17mm on flywheel
Custom intake
17mm PHBG
no air filter
65-starter(too rich)
42-idle
70-main
262au-atomizer
au-bushing
50-slide (edited)
Re: High RPM Blowback, and Lean.
Probably Fred /
Boss circuit pipe ?
What needle?
42 idle is kinda high
70 main seems low
K&n filter will help
Boost bottle will help too
Ed - Dead Possums /
Sorry, Tecno Circuit pipe
W6 needle.
I know now after a bit of riding that the idle 42 is too big.
Air filter, I have a malossi in the mail already.
As for the main, my elevation is only 1000ft. I have a 16mm phbg that runs a 62 main jet. Also seems low to me, but even my plug chops a bit rich.
I have a boost bottle, I might try that too!
Luke “Funkenet” Hosfield /
K&n filters also get clogged with fuel. Would be recommend.
I get blowback like crazy on a 19 phgb and kstar pp but it's in the low rpm range.
Probably Fred /
Lower elevation higher jet
Ed - Dead Possums /
Yeah... I know. Don't know why I'm running small jets. I've started with much bigger and worked my way down.
Ed - Dead Possums /
Fixed all this with a 60 starter, 37 idle, 72 main, needle, second from top, and malossi filter..could maybe go back down to a 70 with the filter. Also installed the boost bottle. Not sure how well it works, if any, but the acceleration is perfect and smooth. Very quick, great midrange, and still hits 51mph at about 10,000 RPMs!
That bike is filthy. They oughta lock you up.
Ed - Dead Possums /
Yeah you like!
