I don't have a lot of cylinders laying around,And need to know what other makes might work on a QT50. I understand the 50cc chappy and possible Minarelli cylinders can work,But not a direct swap.
Thanks
Thanks
all these bike's cylinders will fit. maybe even the later model minarelli vertical cylinders too. Also I think puch cylinders have the same, or close enough, bolt pattern but idk about the base to deck distance(needs to be the same or shorter and then use a base spacer).
Thanks,Ryan I liked the way you searched by the part number. I never thought of trying the Puch,Cylinder. I have an E50 cylinder sitting around.I blew the motor with the PW cylinder, My QT will probably get the YT cylinder. I'm thinking more about experimenting with the motor for my 3 wheeler.
