Honda did a great job with their OEM pipe but it is a heavy turd compared to any of the other performance pipes out there. There are 36 holes in the baffle that could be opened up to provide a better flow. I have done 12 of the 36 and will run the stock pipe with a 70 kit. I have a 50cc Homeot that I will also use and repack it with fibreglas . the baffle in the OEM can be gently removed from the end of the pipe, if stuck with carbon build up and use some PB Blaster and let it soak.
Re: MB5 Exhaust Pipe Options?
