stock V1 - I'm at about a 100 lbs with fresh rings and honed cylinder - only has about ten miles on it - hoping this will go up a bit when the rings seat. What's considered a good number?
What would you say the compression should be on a ...
Re: What would you say the compression should be on a ...
125-130 would be ideal with manageable heat issue.
