Re: vespa ciao DR kit
i just built one of those mazzuchelli cranks, the woodruff slot isn't even close to deep enough, it must be made for a different key. You just have to grind the flat part off 1/8" or so. hand file works good holding it with some pliers.
Yeah DR keeps it real in all of their kits I have had.
I like the Pacco or Spaco or Spacco or whatever Indian SHAt knock off is called.
How do you like the TOP crank?
Is it shaped like a stock crank or like a stock crank that got cutted?
The stock cranks are bad enough but I imagine the performance cranks are even harder metal.
I would suggest a Kinetic CDI for your next upgrade. They are cheap (relatively speaking) and the flywheels weigh a lot less. Plus they are 12v.
Do you prefer the variator or the stock pulley?
I have always run variators on my Vespas but some people whose tuning creds check out have told me the stock pulley 1 speedness is the way to go.
Hey u takin bout my crank! Yea
top cranks are crap DO NOT BUY ONE WHEN YOU CAN GET A MAZI
@tate - I'll wake up yer stock vari with some custom 6061 weights that weigh 1/4 as much as the brass ones.
yea the top crank i recieved was completely pitted and trashed. i sent it back and got the cut mazz crank. some day ill hook up the wiring and drive it.
