Re: vespa ciao DR kit
Justin Davis /
Quick question what happens when they leak?
I used the stock on my 43 polini kit on bravo and you can see where it blows out a little
Tim Ostrom Wrote:
> yeah. loose that crap and get some fel-pro from
> autozone. i take the kit in one hand and lay a
> piece of g.paper across the palm of the other,
> then kinda press the skirt into the paper. trim
> out the circle for the skirt to fit in. then lay
> the paper on the mating surface. push your finger
> over the stud holes, get them perfect, then do the
> transfers. get it really perfect. then use that as
> a template for matching. i use a tile cutter bit
> in a dremel on a pretty low speed. then some emory
> cloth. nice smooth transition.
> then just slther it in indian head and put it
> together w/ no gasket, if you wanna be BA.
  vespa ciao DR kitTopic by: ben hooker ben hooker 07/11/12 04:47PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 07/11/12 06:12PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/11/12 08:28PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/11/12 08:51PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 07/12/12 04:01AM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/12/12 09:07AM
  Re: vespa ciao DR kitRe: Zacarias Aviles Zacarias Aviles 03/24/13 07:32PM
  Re: vespa ciao DR kitRe: Brad Cat Brad Cat 07/12/12 06:08AM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/12/12 09:08AM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 07/12/12 01:51PM
  Re: vespa ciao DR kitRe: Justin Davis Justin Davis 07/18/12 03:59PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/18/12 04:05PM
  Re: vespa ciao DR kitRe: Cole Doubt Cole Doubt 07/12/12 04:11PM
  Re: vespa ciao DR kitRe: Brad Cat Brad Cat 07/12/12 07:18PM
  Re: vespa ciao DR kitRe: Cole Doubt Cole Doubt 07/13/12 05:47PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/18/12 03:02PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/18/12 07:48PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 07/20/12 02:06AM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 08/08/12 01:15PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 08/08/12 02:31PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 08/08/12 01:41PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 08/08/12 01:55PM
  Re: vespa ciao DR kitRe: Joey Hagins Joey Hagins 08/08/12 02:14PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 08/09/12 12:08AM
  Re: vespa ciao DR kitRe: Born to be WillD Born to be WillD 08/09/12 10:26AM
  Re: vespa ciao DR kitRe: Adam H Adam H 08/21/12 12:47PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 08/21/12 05:52PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 08/23/12 05:03PM
  Re: vespa ciao DR kitRe: Walt W Walt W 08/25/12 01:03PM
  Re: vespa ciao DR kitRe: Brad Cat Brad Cat 03/25/13 01:04PM
  Re: vespa ciao DR kitRe: Graham Motzing Graham Motzing 03/25/13 04:55PM
  Re: vespa ciao DR kitRe: Tate The Great Tate The Great 03/25/13 05:45PM
  Re: vespa ciao DR kitRe: Marc Friedman Marc Friedman 03/25/13 06:22PM
  Re: vespa ciao DR kitRe: JOE PEG JOE PEG 03/25/13 06:30PM
  Re: vespa ciao DR kitRe: Deadped Ryan Deadped Ryan 03/25/13 10:20PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 03/27/13 11:09AM
