Re: vespa ciao DR kit
mit mortso /
yeah. loose that crap and get some fel-pro from autozone. i take the kit in one hand and lay a piece of g.paper across the palm of the other, then kinda press the skirt into the paper. trim out the circle for the skirt to fit in. then lay the paper on the mating surface. push your finger over the stud holes, get them perfect, then do the transfers. get it really perfect. then use that as a template for matching. i use a tile cutter bit in a dremel on a pretty low speed. then some emory cloth. nice smooth transition.
then just slther it in indian head and put it together w/ no gasket, if you wanna be BA.
  vespa ciao DR kitTopic by: ben hooker ben hooker 07/11/12 04:47PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 07/11/12 06:12PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/11/12 08:28PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/11/12 08:51PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 07/12/12 04:01AM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/12/12 09:07AM
  Re: vespa ciao DR kitRe: Zacarias Aviles Zacarias Aviles 03/24/13 07:32PM
  Re: vespa ciao DR kitRe: Brad Cat Brad Cat 07/12/12 06:08AM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/12/12 09:08AM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 07/12/12 01:51PM
  Re: vespa ciao DR kitRe: Justin Davis Justin Davis 07/18/12 03:59PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/18/12 04:05PM
  Re: vespa ciao DR kitRe: Cole Doubt Cole Doubt 07/12/12 04:11PM
  Re: vespa ciao DR kitRe: Brad Cat Brad Cat 07/12/12 07:18PM
  Re: vespa ciao DR kitRe: Cole Doubt Cole Doubt 07/13/12 05:47PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/18/12 03:02PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/18/12 07:48PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 07/20/12 02:06AM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 08/08/12 01:15PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 08/08/12 02:31PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 08/08/12 01:41PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 08/08/12 01:55PM
  Re: vespa ciao DR kitRe: Joey Hagins Joey Hagins 08/08/12 02:14PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 08/09/12 12:08AM
  Re: vespa ciao DR kitRe: Born to be WillD Born to be WillD 08/09/12 10:26AM
  Re: vespa ciao DR kitRe: Adam H Adam H 08/21/12 12:47PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 08/21/12 05:52PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 08/23/12 05:03PM
  Re: vespa ciao DR kitRe: Walt W Walt W 08/25/12 01:03PM
  Re: vespa ciao DR kitRe: Brad Cat Brad Cat 03/25/13 01:04PM
  Re: vespa ciao DR kitRe: Graham Motzing Graham Motzing 03/25/13 04:55PM
  Re: vespa ciao DR kitRe: Tate The Great Tate The Great 03/25/13 05:45PM
  Re: vespa ciao DR kitRe: Marc Friedman Marc Friedman 03/25/13 06:22PM
  Re: vespa ciao DR kitRe: JOE PEG JOE PEG 03/25/13 06:30PM
  Re: vespa ciao DR kitRe: Deadped Ryan Deadped Ryan 03/25/13 10:20PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 03/27/13 11:09AM
