Re: vespa ciao DR kit
mit mortso /
just match the skirt to the top transfers. don't go all the way back. like little scoops taken out of the mating surface. it just wastes case pressure if u go all the way back. ramp the side transfers just enough for a smooth transition. i've been blasting mine for around 2 years w/ various pipes. i run a 69 or 70 jet in my 13 sha w/ opened intake and malossi knockoff airbox. didn't mess w/ the crank at all. i get damn close to 50mph w/ good takeoff with the calibratta. i had an old style malossi too bad and that did 45 w/ crazy wheelie power. polini variator and morini style rear clutch. when i first put it together i ran the stock head with no gaskets, just compound on the base. it was fine. then i got the proper head (dr) and put a base gasket in there when i got the calibratta. i never really put much into timing it, just had the points a little more open w/ the circuit, and a little less open w/ the cali. i think mine gets a little hot if i run it wot for a few miles, but i've never seized it.
needs a little chamfering of the ports, but dr chamfered the rings so that was nice.
is this your first kit?
great kits!
  vespa ciao DR kitTopic by: ben hooker ben hooker 07/11/12 04:47PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 07/11/12 06:12PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/11/12 08:28PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/11/12 08:51PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 07/12/12 04:01AM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/12/12 09:07AM
  Re: vespa ciao DR kitRe: Zacarias Aviles Zacarias Aviles 03/24/13 07:32PM
  Re: vespa ciao DR kitRe: Brad Cat Brad Cat 07/12/12 06:08AM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/12/12 09:08AM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 07/12/12 01:51PM
  Re: vespa ciao DR kitRe: Justin Davis Justin Davis 07/18/12 03:59PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/18/12 04:05PM
  Re: vespa ciao DR kitRe: Cole Doubt Cole Doubt 07/12/12 04:11PM
  Re: vespa ciao DR kitRe: Brad Cat Brad Cat 07/12/12 07:18PM
  Re: vespa ciao DR kitRe: Cole Doubt Cole Doubt 07/13/12 05:47PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/18/12 03:02PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 07/18/12 07:48PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 07/20/12 02:06AM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 08/08/12 01:15PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 08/08/12 02:31PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 08/08/12 01:41PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 08/08/12 01:55PM
  Re: vespa ciao DR kitRe: Joey Hagins Joey Hagins 08/08/12 02:14PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 08/09/12 12:08AM
  Re: vespa ciao DR kitRe: Born to be WillD Born to be WillD 08/09/12 10:26AM
  Re: vespa ciao DR kitRe: Adam H Adam H 08/21/12 12:47PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 08/21/12 05:52PM
  Re: vespa ciao DR kitRe: mit mortso mit mortso 08/23/12 05:03PM
  Re: vespa ciao DR kitRe: Walt W Walt W 08/25/12 01:03PM
  Re: vespa ciao DR kitRe: Brad Cat Brad Cat 03/25/13 01:04PM
  Re: vespa ciao DR kitRe: Graham Motzing Graham Motzing 03/25/13 04:55PM
  Re: vespa ciao DR kitRe: Tate The Great Tate The Great 03/25/13 05:45PM
  Re: vespa ciao DR kitRe: Marc Friedman Marc Friedman 03/25/13 06:22PM
  Re: vespa ciao DR kitRe: JOE PEG JOE PEG 03/25/13 06:30PM
  Re: vespa ciao DR kitRe: Deadped Ryan Deadped Ryan 03/25/13 10:20PM
  Re: vespa ciao DR kitRe: ben hooker ben hooker 03/27/13 11:09AM
