Side bleed = higher temps?
I have a side bleed estoril on my e50 and it always seems to run in the 360-400 degree range. I've had three different kits with three different carbs, but always the same pipe. I've even cut back my timing to 1.2 and my compression to 120, but no improvement. So is it the pipe, or what?
Re: Side bleed = higher temps?
Overpriced Parts /
Timing to 1.0 or 16 ish degrees or mm on flywheel and raise gearing to keep revs down
