Hobbit CDI
CtpEDsHED . /
Has anyone ever used this.?
https://www.treatland.tv/honda-hobbit-HPI-CDI-ignition-lights-p/honda-hobbit-hpi-cdi-w-light.htm
https://www.treatland.tv/HPI-CDI-computer-programmable-dual-curve-p/hpi-cdi-tuner-kit.htm
What curves have you made.
I figure.........
1 for hills/quick take-off
2 for hi-rpm blasts-----like downhill and flats.
If rip to like 45---i could switch from 1-2 OR
Have 2 a retarded gas saving setting?? 1 to blast - off.
I'm gonna do this tonite, bolt it up and make a curve.
So...
I'm looking for some recommended timing degrees@certain RPM's.
-Polini Cast iron 70cc----mild porting-case is matched to ports-exh.transfer
-Green Crank--new bearings and seals
-Keihn carb with 92----21 malossi n intake is ready on bench after break-in.
-TJT with dr. pulley slider weights 3.5 grams
-little sanded head----70 hi-comp when it comes back from machining.
-.4 carbon fiber reeds
-gonna use the bu8h plugs the center electrode ones...
I figure graham and Wayne could help out here....
I figure
