Can't find timing marks on a stock Maxi
Jeff Woodin /
Took off my flywheel cover but I can't find the T and F marks like Fred's guide talks about. I also can't see any marks on the engine case. Is it normal for these to get worn away on older bikes? Mine's a 77 Maxi, 1.5 hp. How can I set the timing if I can't find these marks?
Re: Can't find timing marks on a stock Maxi
Some came with them and others didn't..
You need to create a reference point on the case by the flywheel....
Actually I would type this all out but there is a thread about callipers vs micrometers very recently that talks about this in great detail. There is even a video linked. Check it out.
i have never seen facroty timing marks on a puch. just use a marker or something sharp to make some.
The split where the cases meet makes a nice reference point.
timothy rendall /
Hello! I also don't have marks on the fly wheel, but I looked it up on the WIKI and on you -tube It is quite easy to do.
First set your points to the right gap.
Then Find T.D.C. and put a mark on your fly wheel next to the split in the case ( I used the rear split as it was easyer to use)
Next make a mark 16 to 18mm to the left or right depending on your crank rotation of your modle
This is your timing mark.
I used a zenon timing light to get mine spot on.
I hope this helps.
( to all you out there who have been doing this for years sorry if not 100% but every one was a newby once. and I'm more used to 4strokes)
