Doppler ER3 without clutch for Peugeot question
So it seems that the clutchless ER3 for Peugeot does not have the oval base that the Malossi Variotop has; am I missing something? What keeps the variator from spinning on the crank?
Re: Doppler ER3 without clutch for Peugeot question
As you can see here, the Variotop has an oval mount base (I'm sure there's a proper term for that) but the ER3 does not:
ER3:
Variotop:
it's just held in place with the force of the nut the bidalot is like that too. I have run both of them, with no problems, on some high power set ups.
humf. okay... I think I may do a little welding then. I just wasn't sure if I got the wrong shaft or something.
I suppose with the direction of rotation that it would keep torque on the nut, but still that seems like slightly lazy engineering.
derbeez ryderz /
Yea I remember seeing that when I first got a doppler and said how's that gonna work. But that's always spinning with a clutch pulley so it probably doesn't see that much of a load.
