Looking to mod my stock NC50 with a 70cc DR kit and trying to figure out what to do for a head on it. Anyone have suggestions? Appreciate the help.
DR 70cc head to use?
Re: DR 70cc head to use?
factory. or mill factory
same problem, how much to mill? have a small head leak at bottom of cylinder there is a hole in the kit cylinder and head gasket but not in the stock head? tryed torquing retorquing, old and new gaskets, still have leak and only 90psi? should i use the copper head gasket spray?
that hole is for hobbit decomp. tap the hole and use a set screw to plug it
i'd agree with the factory head... they dissapate heat much better.. i bought an athena high head for my urban and didnt gain much.. a little bit more low end on take off and higher temps... be careful.. i wasnt woth it.. i took it back off and gained back the 2-3 mph i lost.. (my experience anyway)
82 guru
mill it right to the fins huh? how far from the spark plug tip are you getting?
thanks I appreciate the help. My original stock was falling apart so I guess I'll replace with a new stock and mill it. I might have more questions. Newbie with the Hondas. Thanks!
Do I want a new head with a decomp or no? Sorry for more dumb questions.
save some money and find a nice used one off the ad's on this site or ebay...i dont have the decomp on mine and have no issues.. u could always add it later if needed.. 4 bolt and its off..
like mentioned get some glue back sand paper and lay it flat on glass.. at the end u can go to 320 or 400 grit for the finial for a nice more polished look... or wetn dry 600 if u want to overkill..u may want to read up more on "checking squish band "as far as checking depth/pressure..
good luck..
82 guru
No you can just use a stock nc50 head and for more compression mill it down to the fins(or no head gasket to gain compression if it don't leak).you could use a head off na(express2),nu(urban express),or pa(hobbit with decomp).Wiki says puch heads will work by widening the bolt holes a little
I have some stock heads for nc50 if you want to pm me.Probly $15 shipped
