kickstart springs?
to get these to engage when i want and help with acceleration i have them turned out very far.. exposing 1.5 to 2 threads at top of screw.. is this "ok" and/or normal setting for these on a puch 2shoe.. also any opinions between these and blue high tension springs..?
Re: kickstart springs?
No. screw them in more. You WANT your clutch to slip. Usually till around 25.
The kick start springs should have a higher tension than the blue springs. If you want less tension you can get weaker springs.
hmm, i thought the clutch slipping earlier would improve my initial acceleration.. but thanks.. if im
