Drilling out a Binger 12 and intake
Michael Thomas /
I have heard of people doing this and I think I am going to try. Drill out both ends of the intake and the carb. Any body have any sizes and suggestions? Looking to end up about 14 mm.
Thanks
Re: Drilling out a Binger 12 and intake
Sounds impossible...
It is impossible just call and ask Gary.
Michael Thomas /
THAT SUCKED!!!!!6 SPINS!!!!
I drilled my intake out for my 15mm Bing, it wasn't too bad at all, just go slow and use some lubricant so the bit won't get caught and jerk around. Check it with a micrometer and make sure you don't get too crazy with it because you'll crack it when you tighten it down otherwise.
dwayne harbeson /
i am running a drilled 12mm bing drilled to 16mm intake as well run's 50-55 wth 70cc tccd kit took out idle screw works great with a 78 jet 2.22 atomizer.
dwayne harbeson /
Don't hate u homo congragulate....
Michael Thomas /
I would use a drll press if I decide to do it.
^^ So your just going to sit & spin with your 12mm in your hand?.
Rollo Tomassi /
I don't like Crazy Wayne anymore. He just ruined that song for me. Forever. I should have known better.
