Voltage regulator+ lighting coil woes
Alright so today i got my lighting oil and voltage regulator in the mail and im siked to get some 12 volt power. I purchased this regulator-https://www.treatland.tv/heavy-duty-DC-voltage-regulator-rectifier-p/dc-voltage-regulator-rectifier.htm. And this lighting coil- https://www.treatland.tv/puch-CDI-internal-LIGHT-coil-p/puch-cdi-internal-light-coil.htm. I have a 12 volt 1ah battery under the seat and two 50 watt lights up front that i want 12 volt. But i need help setting it up. I know electrical just not how to hook this up and hat is a floating ground??? Thanks
Re: Voltage regulator+ lighting coil woes
And how will running two 50 watt head lights plus rear / brake lights off a 55 watt winding make your bike go faster?
This is the PERFORMANCE FORM.
Sorry wrong one
Overpriced Parts /
It will go faster cause after he burns up the 55 watt coil from running 120 watt load then there will be no more power taken off of the crankshaft . It's kinda like disconnecting your alternator on your car at the drags to get .001 sec faster.
That's what i was thinking ,but i was going to let him smoke the winding for shits agigels.
Hell if he did a search he wold find that this has all been covered like 100 post down from this one.
Ok i just didnt understand those so thanks:)
A link fore those that did a search for, How to convert AC to DC with a DIY Rectifier and or install a 12v Regulator, light coils mods and wiring.
Use this link and don't tell Nathan.
https://www.mopedarmy.com/forums/read.php?7,3074968,page=1
