Re: A35 Porting
Josh Cranston /
Adam, it is right at 200*... This is LITERALLY as high as you can go on a A35 cylinder (or atleast as high as I think you would ever want to take it), if I go any higher I'm pretty sure I will cut through the wall of the casting. I was sitting there last night staring at the cylinder thinking "WTF have I done???". I REALLY need to get my hands on a right angle pencil grinder so I can fix my blowdown, its at like 40* right now (good lord). I could raise the intake which could fix blowdown timing, but I think it'll screw up the carter flow too bad. This thing is either gonna be a goofy looking doorstop or it could fly to the heavens when I get done with it. Im gonna try this cylinder out sometime soon hopefully. I just got done yesterday putting K10 forks on my bike, Ive gotta get an axle and bore out the handlebar mounts before I get anywhere with that, so until then she sits parked (Also gotta convert my wheel for disc brakes, should be cake). I've also got a puch high comp head that I think Im gonna have to machine to get the compression where it should be, considering my timing is now 200*.
I'm just now starting to realize how crazy I might be...
  A35 PortingTopic by: Josh Cranston Josh Cranston 06/25/12 09:21PM
  Re: A35 PortingRe: Saabsonettguy . Saabsonettguy . 06/25/12 09:48PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/25/12 10:14PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/25/12 10:19PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/28/12 09:43PM
  Re: A35 PortingRe: OGvandal MPG OGvandal MPG 06/29/12 11:47AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/29/12 10:54PM
  Re: A35 PortingRe: OGvandal MPG OGvandal MPG 06/30/12 09:15AM
  Re: A35 PortingRe: Saabsonettguy . Saabsonettguy . 06/30/12 12:24PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/30/12 01:41PM
  Re: A35 PortingRe: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 06/30/12 06:56PM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/18/12 11:59PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:10AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/30/12 09:08PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 03:47PM
  Re: A35 PortingRe: Jake P Jake P 07/02/12 03:58PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 04:13PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 04:25PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 07/02/12 08:18PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 07/05/12 02:16AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 02:30AM
  Re: A35 PortingRe: louis partida louis partida 10/18/12 09:38PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 09:56PM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:13AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:20AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:30AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:39AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:47AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:18AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/18/12 10:58PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 11:11PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:23AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:55AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/19/12 01:00AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 01:03AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/20/12 06:48PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 12:04AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/22/12 02:22PM
  Re: A35 PortingRe: LSLB RXb LSLB RXb 10/22/12 03:00PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:15PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:16PM
  Re: A35 PortingRe: Jesse Brosnan Jesse Brosnan 10/22/12 05:09PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:19PM
