Re: A35 Porting
Josh Cranston /
You do realize that I have run the cylinder as it was and it ripped right (and I was only at 172* exhaust duration which is kinda conservative)? Ive widened the exhaust port as far as I can without hitting the ring ends, I havent relocated them yet. And I milled the stock head to compensate for any compression loss, plus I have a high comp head to throw on since I did the most recent work to compensate even more. Also, the port itself is very straight from what work I did to it, and it is polished to mirror smooth. I can't do much more or I will cut through the casting (I'll have a hole pretty much).
Not trying to be a dick, but do you actually know anything about porting? What are your port durations from what you did? What pipe are you running? If you just hap-hazardly port and don't match different variables, your bike will run shitty. I planned out what I did and I was very happy with what I did. You wouldnt want to port your bike like mine unless you planned on racing it, for general use my setup sucks.
  A35 PortingTopic by: Josh Cranston Josh Cranston 06/25/12 09:21PM
  Re: A35 PortingRe: Saabsonettguy . Saabsonettguy . 06/25/12 09:48PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/25/12 10:14PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/25/12 10:19PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/28/12 09:43PM
  Re: A35 PortingRe: OGvandal MPG OGvandal MPG 06/29/12 11:47AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/29/12 10:54PM
  Re: A35 PortingRe: OGvandal MPG OGvandal MPG 06/30/12 09:15AM
  Re: A35 PortingRe: Saabsonettguy . Saabsonettguy . 06/30/12 12:24PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/30/12 01:41PM
  Re: A35 PortingRe: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 06/30/12 06:56PM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/18/12 11:59PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:10AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/30/12 09:08PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 03:47PM
  Re: A35 PortingRe: Jake P Jake P 07/02/12 03:58PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 04:13PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 04:25PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 07/02/12 08:18PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 07/05/12 02:16AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 02:30AM
  Re: A35 PortingRe: louis partida louis partida 10/18/12 09:38PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 09:56PM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:13AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:20AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:30AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:39AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:47AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:18AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/18/12 10:58PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 11:11PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:23AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:55AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/19/12 01:00AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 01:03AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/20/12 06:48PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 12:04AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/22/12 02:22PM
  Re: A35 PortingRe: LSLB RXb LSLB RXb 10/22/12 03:00PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:15PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:16PM
  Re: A35 PortingRe: Jesse Brosnan Jesse Brosnan 10/22/12 05:09PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:19PM
