Re: A35 Porting
Josh Cranston /
Ok, thought I would resurrect this thread. That second port job I posted way back when is a beast when coupled with the right pipe. I ran it at the last NEMA race this season with a new custom pipe I designed, along with down gearing some more to 24/28. Absolutely friggin rocked. My top speed was most definitely higher than it had been with the techno circuit (even with the lower gearing) and mid range acceleration drastically increased (to the point where it wants to throw you off the bike when the pipe hits... anyone is welcome to ride the bike if they don't believe me haha). Also note that I changed out the clutch springs to 30lb on BOTH clutches, much much better. I just got finished this evening raising the exhaust duration some more... Ill post a new port map when I get it done. I'm hoping to get my RPMs up to at least 13K+ by the time I'm done (Probably will end up gearing at 24/31 when I'm done too, top speed will be similar but I'm more looking for the get-up-and-go).
Also, don't use this gearing or porting for everyday use, this is race only stuff. Although the acceleration is pretty fucking sweet...
  A35 PortingTopic by: Josh Cranston Josh Cranston 06/25/12 09:21PM
  Re: A35 PortingRe: Saabsonettguy . Saabsonettguy . 06/25/12 09:48PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/25/12 10:14PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/25/12 10:19PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/28/12 09:43PM
  Re: A35 PortingRe: OGvandal MPG OGvandal MPG 06/29/12 11:47AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/29/12 10:54PM
  Re: A35 PortingRe: OGvandal MPG OGvandal MPG 06/30/12 09:15AM
  Re: A35 PortingRe: Saabsonettguy . Saabsonettguy . 06/30/12 12:24PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/30/12 01:41PM
  Re: A35 PortingRe: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 06/30/12 06:56PM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/18/12 11:59PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:10AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/30/12 09:08PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 03:47PM
  Re: A35 PortingRe: Jake P Jake P 07/02/12 03:58PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 04:13PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 04:25PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 07/02/12 08:18PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 07/05/12 02:16AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 02:30AM
  Re: A35 PortingRe: louis partida louis partida 10/18/12 09:38PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 09:56PM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:13AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:20AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:30AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:39AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:47AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:18AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/18/12 10:58PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 11:11PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:23AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:55AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/19/12 01:00AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 01:03AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/20/12 06:48PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 12:04AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/22/12 02:22PM
  Re: A35 PortingRe: LSLB RXb LSLB RXb 10/22/12 03:00PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:15PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:16PM
  Re: A35 PortingRe: Jesse Brosnan Jesse Brosnan 10/22/12 05:09PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:19PM
