Re: A35 Porting
Josh Cranston /
So, this has turned into more of an A35 Tuning thread, but it's all good. Thought I would add a bit from my testing the other day.
Went down to a 65 jet because the 70 was still reading slightly rich on the plug. I dont have a temp gauge so I don't actually know how hot it's getting in there, but it doesnt 4 stroke as bad in the mid range as it did with the 70 main (and opens up a little better on top). Also switched out to a 4F15 needle, slightly richer needle but in combo with the 65 main jet, works great (at middle position right now). Also found out that the 15 idle jet was too small, went to a 17.5, still too small (would only idle with the choke on). It ran fine the other day with the 15, but maybe it was something about the weather, don't really know. May go back to the 30 as I don't really have any other idle jets and although the 30 is rich, it idled pretty well.
Still wishing I had some asphalt to ride on to really get some testing in, can't ride this thing on the street (Id get pulled over in a millisecond).
  A35 PortingTopic by: Josh Cranston Josh Cranston 06/25/12 09:21PM
  Re: A35 PortingRe: Saabsonettguy . Saabsonettguy . 06/25/12 09:48PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/25/12 10:14PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/25/12 10:19PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/28/12 09:43PM
  Re: A35 PortingRe: OGvandal MPG OGvandal MPG 06/29/12 11:47AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/29/12 10:54PM
  Re: A35 PortingRe: OGvandal MPG OGvandal MPG 06/30/12 09:15AM
  Re: A35 PortingRe: Saabsonettguy . Saabsonettguy . 06/30/12 12:24PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/30/12 01:41PM
  Re: A35 PortingRe: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 06/30/12 06:56PM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/18/12 11:59PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:10AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/30/12 09:08PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 03:47PM
  Re: A35 PortingRe: Jake P Jake P 07/02/12 03:58PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 04:13PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 04:25PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 07/02/12 08:18PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 07/05/12 02:16AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 02:30AM
  Re: A35 PortingRe: louis partida louis partida 10/18/12 09:38PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 09:56PM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:13AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:20AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:30AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:39AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:47AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:18AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/18/12 10:58PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 11:11PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:23AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:55AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/19/12 01:00AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 01:03AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/20/12 06:48PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 12:04AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/22/12 02:22PM
  Re: A35 PortingRe: LSLB RXb LSLB RXb 10/22/12 03:00PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:15PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:16PM
  Re: A35 PortingRe: Jesse Brosnan Jesse Brosnan 10/22/12 05:09PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:19PM
