Re: A35 Porting
Saabsonettguy . /
Did you have to run a spacer on the base to get the ports to open fully at BDC? The main difference from the one I'm working on is that I'm keeping the intake bridge. I'll be running a single ring piston with the locating pin on the intake side. That should allow me to widen the exhaust a bit, which you can't do much of with the stock piston due to the close proximity of the ring ends to the exhaust port.
  A35 PortingTopic by: Josh Cranston Josh Cranston 06/25/12 09:21PM
  Re: A35 PortingRe: Saabsonettguy . Saabsonettguy . 06/25/12 09:48PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/25/12 10:14PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/25/12 10:19PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/28/12 09:43PM
  Re: A35 PortingRe: OGvandal MPG OGvandal MPG 06/29/12 11:47AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/29/12 10:54PM
  Re: A35 PortingRe: OGvandal MPG OGvandal MPG 06/30/12 09:15AM
  Re: A35 PortingRe: Saabsonettguy . Saabsonettguy . 06/30/12 12:24PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/30/12 01:41PM
  Re: A35 PortingRe: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 06/30/12 06:56PM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/18/12 11:59PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:10AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 06/30/12 09:08PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 03:47PM
  Re: A35 PortingRe: Jake P Jake P 07/02/12 03:58PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 04:13PM
  Re: A35 PortingRe: get2 stroken! get2 stroken! 07/02/12 04:25PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 07/02/12 08:18PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 07/05/12 02:16AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 02:30AM
  Re: A35 PortingRe: louis partida louis partida 10/18/12 09:38PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 09:56PM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:13AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:20AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:30AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:39AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:47AM
  Re: A35 PortingRe: louis partida louis partida 10/19/12 12:18AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/18/12 10:58PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/18/12 11:11PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:23AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 12:55AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/19/12 01:00AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/19/12 01:03AM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/20/12 06:48PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 12:04AM
  Re: A35 PortingRe: - Summerai - Drew - Summerai - Drew 10/22/12 02:22PM
  Re: A35 PortingRe: LSLB RXb LSLB RXb 10/22/12 03:00PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:15PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:16PM
  Re: A35 PortingRe: Jesse Brosnan Jesse Brosnan 10/22/12 05:09PM
  Re: A35 PortingRe: Josh Cranston Josh Cranston 10/22/12 10:19PM
