Ok here is where Im at as of today. AND THIS IS DRIVING ME FKN CRAZY!
Here is what I have:
Tomos a35
Techno Boss pipe
Dellorto 17.5 Carb 92 fuel jet
Airsal kit
I got it running pretty solid with adjustment of the needle.
Yesterday I decided to bore out the factory a35 intake to 3/4in(17mm) to potentially match my carb and changed the reeds to Mollassi carbon from 1977 but they were too long initially and wouldn't allow any air flow to pass, so I had to trim them slightly.
Just checked compression and the the carb 10x and everything is up to par.
The carb is currently at the following.
Starter jet: 50
Idle Jet: 25
Main: 84
Needle: 2nd from the bottom.
Ive tried downsizing main jet to 60's and every needle adjustment and all have failed worst then the current settings.
Appears to run but doesn't idle the greatest. Gets up to about 35mph but definitely has lost some low end torque and high end speed.
What gives??? Suggestions/ Input please????!!!!
