which produce better performance? I'm running the malossi h20 kit. and i'm just wondering if somebody had experience experimenting with both of them
I am about to do the same 50cc Malosssi h2o build and was told the stock case was the way to go by these guys...
He said stock cases work better on a 50cc. Look what he builds, i trust him!
Stock works fine, but honestly there isn't that huge of a difference. If you are planning to do something huge like a 22-24 mm carb and port for crazy rpms you may benefit more from polini cases than I did. I would tell a newb just to go for stock cases merely because it is cheaper.
