av10- polini cases vs stock cases
Mike Piarowski /
which produce better performance? I'm running the malossi h20 kit. and i'm just wondering if somebody had experience experimenting with both of them
Re: av10- polini cases vs stock cases
Ed - Dead Possums /
I am about to do the same 50cc Malosssi h2o build and was told the stock case was the way to go by these guys...
Tomahawk
He said stock cases work better on a 50cc. Look what he builds, i trust him!
Tracy Meade /
Stock works fine, but honestly there isn't that huge of a difference. If you are planning to do something huge like a 22-24 mm carb and port for crazy rpms you may benefit more from polini cases than I did. I would tell a newb just to go for stock cases merely because it is cheaper.
