Ignition timing
I put in the 70 cc alukit on my tomos a35. I wanted to know how important is it to reset the ignition timing? Can I get by with out doing this?
Re: Ignition timing
Luke “Funkenet” Hosfield /
Its not hard, and yes you should make sure it's timed correctly. If you are too advanced you will run too hot and say goodbye to your new kit.
Re: Ignition timing
Bobby Cazeault /
Do I need to buy a new Cdi or can I just adjust what I have it's just stock.
Re: Ignition timing
The stock ignition is adjustable. The stator plate is simply rotated one way or another on slotted holes to adjust the timing. Check out the wiki for more info.
