Re: 103 stock variator, rubber under one weight, wtf?
elm . /
it slows the variation, which i don't mind, but it seems to prevent full variation as well. the part of the arm that touches the rubber has a u-shaped cross section instead of o-shaped, so it stops when the flat part hits the rubber.
so i get to decide if i want to remove it for full variation, or cut it in half and make both sides even. or something else.
