Re: Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?
Bobby Cazeault /
The spreadsheet is totally all over the map. If I were you I would start in the mid 80's and go down to like 65, I don't think that you will end up in the 80's but it won't hurt to start there. Got a a35 65 cc performance pipe stock carb performance air filter and I'm at 65 with the plug looking good.
  Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?Topic by: Walker Quine Walker Quine 06/22/12 02:51AM
  Re: Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?Re: Brad Cat Brad Cat 06/22/12 03:54AM
  Re: Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?Re: Walker Quine Walker Quine 06/22/12 04:05AM
  Re: Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?Re: Brad Cat Brad Cat 06/22/12 05:13AM
  Re: Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?Re: Walker Quine Walker Quine 06/22/12 02:40PM
  Re: Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?Re: Weak-Ends Tj Weak-Ends Tj 06/22/12 11:26AM
  Re: Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?Re: Walker Quine Walker Quine 06/22/12 02:43PM
  Re: Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?Re: Jonny Appleseed Jonny Appleseed 06/22/12 06:57PM
  Re: Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?Re: Walker Quine Walker Quine 06/22/12 09:33PM
  Re: Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?Re: Jonny Appleseed Jonny Appleseed 06/22/12 09:54PM
  Re: Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?Re: Bobby Cazeault Bobby Cazeault 06/23/12 12:11AM
  Re: Upgrading 2005 Tomos Sprint to 70cc kit, what size carb jet should I use?Re: Walker Quine Walker Quine 06/23/12 01:39PM
