Re: Lets see if we can make a V1 Polini Better
Tim Annett /
I've attached the Mikuni VM manual. Not terribly relevant to the 2t/4t thing but should make for some exciting night time reading.
One of the most important things to do when setting up your carb is adjusting the float level. One method for getting an acurate float level is to set up a manometer. In other words get some clear fuel line and hook it up to the float bowl drain. Hold the clear line vertical to the carb and open up the float drain. This will show you the fuel level inside the carb.
  Lets see if we can make a V1 Polini BetterTopic by: Aron Chaudiere Aron Chaudiere 06/21/12 03:38AM
  Re: Lets see if we can make a V1 Polini BetterRe: Daniel '' Daniel '' 06/21/12 06:07AM
  Re: Lets see if we can make a V1 Polini BetterRe: Michael Thomas Michael Thomas 06/21/12 12:20PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 06/21/12 03:14PM
  Re: Lets see if we can make a V1 Polini BetterRe: *.* HONDA *.* HONDA 06/21/12 03:31PM
  Re: Lets see if we can make a V1 Polini BetterRe: Rachid Z Rachid Z 06/21/12 06:28PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 06/22/12 03:16PM
  Re: Lets see if we can make a V1 Polini BetterRe: ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin 06/22/12 03:45PM
  Re: Lets see if we can make a V1 Polini BetterRe: ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin 06/22/12 03:51PM
  Re: Lets see if we can make a V1 Polini BetterRe: Rachid Z Rachid Z 06/22/12 05:47PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 06/23/12 02:34AM
  Re: Lets see if we can make a V1 Polini BetterRe: Michael Thomas Michael Thomas 06/23/12 12:05PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 06/24/12 03:45AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 06/27/12 11:10AM
  Re: Lets see if we can make a V1 Polini BetterRe: Rachid Z Rachid Z 06/27/12 03:29PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/04/12 02:47PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/04/12 02:52PM
  Re: Lets see if we can make a V1 Polini BetterRe: Graham Motzing Graham Motzing 07/04/12 03:48PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/04/12 04:26PM
  Re: Lets see if we can make a V1 Polini BetterRe: Rachid Z Rachid Z 07/04/12 04:45PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/05/12 12:58PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/06/12 02:58AM
  Re: Lets see if we can make a V1 Polini BetterRe: CtpEDsHED . CtpEDsHED . 07/06/12 07:44AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/06/12 10:51AM
  Re: Lets see if we can make a V1 Polini BetterRe: RingringBANG ! RingringBANG ! 07/07/12 09:44AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/07/12 12:38AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/07/12 11:21AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/10/12 10:09PM
  Re: Lets see if we can make a V1 Polini BetterRe: Ryan N. Ryan N. 07/10/12 10:33PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/10/12 11:21PM
  Re: Lets see if we can make a V1 Polini BetterRe: Ryan N. Ryan N. 07/10/12 11:28PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/11/12 12:27AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/11/12 12:31AM
  Re: Lets see if we can make a V1 Polini BetterRe: tonynarelli 68 tonynarelli 68 07/13/12 01:48AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/13/12 11:00AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/15/12 03:35PM
  Re: Lets see if we can make a V1 Polini BetterRe: Serious Business Serious Business 07/15/12 08:51PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/17/12 02:13AM
  Re: Lets see if we can make a V1 Polini BetterRe: Mo Peds Mo Peds 07/17/12 10:17AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/17/12 03:05AM
  Re: Lets see if we can make a V1 Polini BetterRe: Charlie BUZZARD Charlie BUZZARD 07/17/12 10:06AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/17/12 11:38AM
  Re: Lets see if we can make a V1 Polini BetterRe: Daniel '' Daniel '' 07/17/12 12:12PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/18/12 12:32PM
  Re: Lets see if we can make a V1 Polini BetterRe: Ben Eberle Ben Eberle 07/18/12 03:49PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/19/12 01:47AM
  Re: Lets see if we can make a V1 Polini BetterRe: Morgan Aguayo Morgan Aguayo 07/19/12 01:56AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/19/12 02:29AM
  Re: Lets see if we can make a V1 Polini BetterRe: *.* HONDA *.* HONDA 07/19/12 08:47AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/19/12 10:52AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/20/12 02:42AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/20/12 02:53AM
  Re: Lets see if we can make a V1 Polini BetterRe: Daniel '' Daniel '' 07/20/12 03:38AM
  Re: Lets see if we can make a V1 Polini BetterRe: Tim Annett Tim Annett 07/20/12 01:22PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/20/12 02:09PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/20/12 05:37PM
  Re: Lets see if we can make a V1 Polini BetterRe: Tim Annett Tim Annett 07/20/12 09:14PM
  Re: Lets see if we can make a V1 Polini BetterRe: Tim Annett Tim Annett 07/20/12 09:17PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/20/12 11:09PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/21/12 01:49AM
  Re: Lets see if we can make a V1 Polini BetterRe: Tim Annett Tim Annett 07/21/12 06:30AM
  Re: Lets see if we can make a V1 Polini BetterRe: Daniel '' Daniel '' 07/22/12 02:39PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/22/12 08:30PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/22/12 11:54PM
  Re: Lets see if we can make a V1 Polini BetterRe: RingringBANG ! RingringBANG ! 07/23/12 10:52AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/23/12 01:07PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/23/12 11:17PM
  Re: Lets see if we can make a V1 Polini BetterRe: Ryan N. Ryan N. 07/23/12 11:41PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/24/12 12:36AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/24/12 01:08AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/24/12 02:57AM
  Re: Lets see if we can make a V1 Polini BetterRe: Shannon Hall Shannon Hall 07/24/12 12:27PM
  Re: Lets see if we can make a V1 Polini BetterRe: Daniel '' Daniel '' 01/02/13 04:14PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/09/13 06:51PM
  Re: Lets see if we can make a V1 Polini BetterRe: Nash . Nash . 01/03/13 01:01AM
  Re: Lets see if we can make a V1 Polini BetterRe: Michael Thomas Michael Thomas 07/09/13 09:28PM
  Re: Lets see if we can make a V1 Polini BetterRe: Luke โ€œFunkenetโ€ Hosfield Luke โ€œFunkenetโ€ Hosfield 07/09/13 10:23PM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/10/13 02:33AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/02/16 01:15AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/02/16 01:16AM
  Re: Lets see if we can make a V1 Polini BetterRe: Toledo Riot Toledo Riot 07/03/16 10:01AM
  Re: Lets see if we can make a V1 Polini BetterRe: Aron Chaudiere Aron Chaudiere 07/10/16 12:15AM
  Re: Lets see if we can make a V1 Polini BetterRe: Ryan Graeme Ryan Graeme 07/10/16 05:09PM
  Re: Lets see if we can make a V1 Polini BetterRe: grim ripper grim ripper 07/11/16 02:28AM
  Re: Lets see if we can make a V1 Polini BetterRe: Daniel '' Daniel '' 07/11/16 12:52PM
  Re: Lets see if we can make a V1 Polini BetterRe: ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin 07/11/16 05:02PM
