plain and simple, why does overjetting increase heat? pipe flow is too slow? or more gas in the mix makes it burn slower? i was jetted at a 80-82 with my 20phbg and mildly ported kstar and biturbo (uni filter) and barely kissed 400 on long uphills, and im geared damn tall (20x40), threw a 86 in there and my temps went up to 410 within a few minutes of riding from a cool engine? and the 78/77 jets i have push the temps down to 350! i thought it was supposed to be the other way around? im timed at 17btdc.
upjet = more heat? whats going on here
Re: upjet = more heat? whats going on here
what is your oil ratio?
Needle bearing crank right? Gear way way down, bi-turbo is a higher revver, and the porting you did should work well to make a high revver.
Tuned length of a biturbo is like 25.6in according to the exhaust monograph, which is even shorter then a boss. Try 15 or 16x40 and see what happens. You've tuned your clutch already right?
50:1 synth stock crank for now (hence the temporary high gear, im usually at 17/40 but decided to throw the 19 on for shits and it made me go FAAST, clutch shoes are lightened about 10g from what they were i think, a little more then 720 out from all the way in on the adjustment. i juuuust got my clutch brace and kickstart springs yesterday, i know the pipe combo is very mismatched with gearing, my plan was to get a lower hitting pipe like a bk100 but i didnt yet. i have a techno circuit with a dent in the chamber laying around...but i cant get it to seal up at the exhaust flange
full setup
kstar 70
b7hs@.018
intake widened, ex widened and raised 1 mm
my compression is pretty low around 130psi even with the hihi comp head due to my squish being sooooo off thanks to the basegaskets...
2 basegaskets so piston clears ex port, also running a headgasket.
takeoff is GREAT, screams up to top speed then nothing....ive always kinda battled with heat. am i just not hitting the pipe at all so the heat is staying in the engine?
” screams up to top speed then nothing”
Which is...?
48-52 ish according to iphone gps
forgot to mention, au262 atomizer, w7 needle, at a 77 main and 45 idle
forgot to mention, au262 atomizer, w7 needle, at a 77 main and 45 idle is what im running now.
this talks about rich and lean temps
http://flighttraining.aopa.org/students/solo/special/mixture.html
i was trying to find this article that mentions a book. In the article it talks about going past 12.3:1 to cool the engine with extra fuel but in fact that doesn't work. idk. Hopefully all you did was a jet change and didn't mess with anything else to get your temp reading. Change one thing then test and repeat, sucks not to be able to change a bunch of stuff at once sometimes but that's what you gotta do to learn.
Too advanced timing is why your battling hi temps
yup all i did was change main jet, gonna read that article now!
http://www.rbracing-rsr.com/waterinjection.html
this is the article I was searching for. it mentions the book under the heading "Don’t Drink the Purple Cool-Aid"
ken im at 17 degrees and have gone so far as 15 and its no different. so i just set it to 17 because it ran better.
Have you reworked the squish band on the hi-hi head? That'll kill higher rpms with heat and give you nice low end.
Ya 17 deg is ok
Ya too much compression or air leak could spike temps .
You could have knocked off a plug on your carb or something when you changed your jet
yes the head is reworked, the plug cup lip has been taken way down, squish border also was pushed back 3-4 mms. absolutely no airleaks, i have the two holes on the non idle adjustment side plugged....maybe one is leaking ? ive sprayed carb cleaner directly on the holes with no rev loss though.....
oh and.... i went for another late night ride last night to confirm with the 77 main its running better then ever and i didnt break 350 at WOT on a mild hill
Well its sounds to be jetted perfect to me. You can actually run hot when running rich...
i never really considered that i wasnt hitting the pipe, im going to regear to 17/40 and see what that does to my top end. hopefully ill actually get some more speed.
Same thing happened with me.Just run with it.
