Re: upjet = more heat? whats going on here
ian van opijnen /
50:1 synth stock crank for now (hence the temporary high gear, im usually at 17/40 but decided to throw the 19 on for shits and it made me go FAAST, clutch shoes are lightened about 10g from what they were i think, a little more then 720 out from all the way in on the adjustment. i juuuust got my clutch brace and kickstart springs yesterday, i know the pipe combo is very mismatched with gearing, my plan was to get a lower hitting pipe like a bk100 but i didnt yet. i have a techno circuit with a dent in the chamber laying around...but i cant get it to seal up at the exhaust flange
full setup
kstar 70
b7hs@.018
intake widened, ex widened and raised 1 mm
my compression is pretty low around 130psi even with the hihi comp head due to my squish being sooooo off thanks to the basegaskets...
2 basegaskets so piston clears ex port, also running a headgasket.
takeoff is GREAT, screams up to top speed then nothing....ive always kinda battled with heat. am i just not hitting the pipe at all so the heat is staying in the engine?
  upjet = more heat? whats going on hereTopic by: ian van opijnen ian van opijnen 06/20/12 08:06PM
  Re: upjet = more heat? whats going on hereRe: Salsa Salsa Salsa Salsa 06/20/12 08:15PM
  Re: upjet = more heat? whats going on hereRe: LSLB RXb LSLB RXb 06/20/12 08:24PM
  Re: upjet = more heat? whats going on hereRe: LSLB RXb LSLB RXb 06/20/12 08:26PM
  Re: upjet = more heat? whats going on hereRe: ian van opijnen ian van opijnen 06/20/12 09:23PM
  Re: upjet = more heat? whats going on hereRe: Jake P Jake P 06/20/12 09:31PM
  Re: upjet = more heat? whats going on hereRe: ian van opijnen ian van opijnen 06/20/12 09:43PM
  Re: upjet = more heat? whats going on hereRe: ian van opijnen ian van opijnen 06/20/12 09:44PM
  Re: upjet = more heat? whats going on hereRe: ian van opijnen ian van opijnen 06/20/12 09:47PM
  Re: upjet = more heat? whats going on hereRe: ian van opijnen ian van opijnen 06/20/12 10:15PM
  Re: upjet = more heat? whats going on hereRe: Ryan Mayer Ryan Mayer 06/20/12 10:02PM
  Re: upjet = more heat? whats going on hereRe: Overpriced Parts Overpriced Parts 06/20/12 10:15PM
  Re: upjet = more heat? whats going on hereRe: Ryan Mayer Ryan Mayer 06/20/12 10:26PM
  Re: upjet = more heat? whats going on hereRe: ian van opijnen ian van opijnen 06/21/12 02:22AM
  Re: upjet = more heat? whats going on hereRe: LSLB RXb LSLB RXb 06/21/12 09:04AM
  Re: upjet = more heat? whats going on hereRe: Overpriced Parts Overpriced Parts 06/21/12 10:36AM
  Re: upjet = more heat? whats going on hereRe: ian van opijnen ian van opijnen 06/21/12 01:11PM
  Re: upjet = more heat? whats going on hereRe: ian van opijnen ian van opijnen 06/21/12 01:30PM
  Re: upjet = more heat? whats going on hereRe: Michael Thomas Michael Thomas 06/21/12 01:50PM
  Re: upjet = more heat? whats going on hereRe: ian van opijnen ian van opijnen 06/21/12 03:26PM
  Re: upjet = more heat? whats going on hereRe: Button Rojo Button Rojo 06/21/12 03:30PM
