Re: Moby motor is twisting
Mick Baltards /
Is there any slop in the mounting? There should not be. If you replaced the silent blocs (main motor mounts), did you put them in the same place as stock? If you did not get the spacing correct, there will be slop. I don't remember the measurements but they have to go back correct.
