Moby motor is twisting
Tyler Jaynes /
My set up right now is the stock av10 cases, doppler spring, stock clutch with the varplus cheek, ER2 pulley, with malossi belt. I've replaced my motor mounts and have aligned the pulleys but whenever I throw my belt on there my motor twists counterclockwise. like in the picture (not sure if it does justice). I did notice that when I was installing the pivot mounts (spacers) that go into the cylinder head they felt loose so I wasn't sure if those could be the problem. I'm just unsure if my doppler spring needs adjusting or if i need to replace those little spacer inserts?
(edited)
