Motobecane Mods
I have a 50V Motobecane and i want it to go faster.... is there anything i can change that wont cost any money? like modifying the variator, muffler, or transmission?
Re: Motobecane Mods
Russell Huddy /
Use the search function and read the wiki
Re: Motobecane Mods
check out Rebel's pipe derestricting on mabecane web sight, and the mild port job in the wiki, and ditch the gurtner carb.
Re: Motobecane Mods
i working on the same bike right now a sha 15.15 carb has me doing 35-40, the exhaust mod seems like a pain because of the math and welding and all that mess so im about to go with a sim pipe ill let you know what happens with that. i understand you dont want to spend money but you gotta know in life you get what you pay for, and when you pay nothing....
Re: Motobecane Mods
You can derestrict the exhause and give the entire bike a maintenance check and service.
http://mabecanemobylette.freeforums.org/viewtopic.php?f=24&t=1394
You can also shave a little off the movable cheek on the variator.
If you have hills and traffic you can convert a 4 ball variator to two balls, but if you have a 3 ball set up then you need to get a 2 ball or 4 ball cage so the balls can be 180 degrees from each other or you go through engine bearings fast, but the 2 or 4 ball cage is not free.
Actually not much else you can do for free for BIG gains. Least expensive is to get the SHA15:15 and 15mm shorty intake, derestrict the pipe and get a cage if you have traffic.
ALWAYS invest in the clutch/cam puller tool if you are a Moby owner
Re: Motobecane Mods
It's funny how every day I look on this forum there is somebody asking the same question. It is a little entertaining to read but yeah... use the search!!!
Re: Motobecane Mods
It is easier sometimes to just answer the question then to explain how to click on Search and explain how to type a key word or two into the box and click on the Search button... specially when someone will come back with "I searched for the answer but did not find it"
> search!!!
Re: Motobecane Mods
We should really just compile a new entry in the wiki that answers this question. I know all the info is there, in separate entries, but if it was in one entry then every time this question is asked somone coudld just cut & paste it as an answer instead of having to re-type the whole shebang.
Re: Motobecane Mods
so i've got a av10 with case reeds and a 19mm dellorto with a 105 main jet and a very restrictive air filter that ends up leaking gas sometimes when im riding . it will happen every time i take it out . any ideas why?
Re: Motobecane Mods
Re: Motobecane Mods
That is why I have posted so many links to Mabecane Forum.. partially because I know where what is resident there, but mainly because I am so terrible at trying to use the wiki that I have this deep fear that I will blow it up if I try to post anything there again.
> shebang.
Re: Motobecane Mods
ive read the wiki many a time as far as the performance tuning goes and i havent found anything on gas leaking from my intake side of my carb. ive tried down jetting as far as a 92 and it was still leaking, i think it has to do with the reeds but the reed section doesnt really have that much info .so what should i read
Re: Motobecane Mods
reeds not closing, prob
